2D Polyline 'ı 3D...
3d polyline'ı 2d...
3D Yay çizen lisp...
Artan sırayla num...
Autocad içinden e...
Civata ve Somun Ç...
Çizgileri toplayı...
Çizime Tarih Yaza...
Daire ortasına ak...
Duvar çizen lisp...
Harita ve pafta k...
İşaretlenen 2 nok...
Merdiven çizen lisp
Nokta koordinatla...
Noktanın koordina...
Parabol çizen lisp
Ziyaretçi: 429, Üye: 3
admin, mateus, sabahsalih
> AutoLISP > Örnek Lispler > 3d polyline'ı 2d polyline'a çeviren lisp
3d polyline'ı 2d polyline'a çeviren lisp, 3d pline to 2d pline, pline converter, pline dönüştürme
admin - 10.10.2006 12:54
3d polyline'ı 2d polyline'a çeviren lisp.
Üreticinin açıklaması:
freecadapps.com
Description: Convert 3d polyline to 2d polyline
Convert 2d polyline, 3dface, line, arc, & circle to 3d polyline
1. Join 3Dpoly's (ends should meet).
2. If you accidently pick a 3DPoly, it is just drawn over again.
3. The Join function will replace the two 3DPolys with a single 3dPoly.
4. The Change function will just draw over the existing entity.
5. For a mesh , first explode it into faces, then change to 3dpoly(s).
6. Resolution will control smoothnes of curves, also make various shapes
such as... 6 = hex, 3 = triangle, 4 = square, etc....
Bu lisp www.freecadapps.com kaynağından alınmış ve halka açık olduğu için paylaşım amacıyla sayfaya eklenmiştir.
;Convert 3d polyline to 2d polyline
(defun c:p3p2 (/ eg cl en e nc fp pt)
(princ "n[Change 3D Polyline to 2D Polyline.]")
(setq e  (entsel "  Select a 3DPoly: ")          ; get the header data
       en (car e)
       cl (if(=(cdr(assoc 70(entget en)))1)1)             ; closed flag 1=yes
       p1 (cdr(assoc 10(entget(entnext en))))
       p2 (cdr(assoc 10(entget(entnext(entnext en)))))
(command "ucs" "3" p1 p2 "")
(setq fp (trans p1 0 1))                                  ; save first point
;       en (entnext en))                                   ; leave header
(setvar "blipmode" 0)
(command "pline")
(command fp)                                             ; id first vertex
(while (/=(cdr(assoc 0(setq eg(entget(setq en(entnext en))))))"SEQEND")
  (setq pt (trans(cdr(assoc 10 eg))0 1))
  (if pt (command pt))
  (if (and (not pt) cl)(command fp))
);endwhile
(command "")
(command "ucs" "w")
(setvar "blipmode" 1)
);end C:P3P2
(princ)(PRINC " --> 'www.autocadokulu.com' Çizim yardımları yüklendi !")
Yazar:
İçerik: LSP formatında AutoLISP dosyası
Tag: 3d polyline'ı 2d polyline'a çeviren lisp, 3d pline to 2d pline, pline converter, pline dönüştürme
  • 2D Polyline 'ı 3D Polyline yapan lisp (33.644)
  • Multi Polyline Lisp (MPL) (11.270)
  • Seçilen Polyline'ların köşe koordinatları, ara mesafeleri, alan ve çevrelerini tablo halinde yazan AutoLisp fonksiyonu (48.916)
  • Ara Lisp (52.616)
  • Enkesit Lisp (8.408)
  • Rectangle Solid (lisp) (31.790)
  • Parabol çizen lisp (25.318)
  • 3D Yay çizen lisp (seçenekli) (27.550)
  • Rakam sıralayan lisp (36.193)
  • Spiral çizen lisp (48.034)
recep_xyz   17.01.2022 11:49 #16102
burada yapılan 3dpline obje korunarak ucs yardımıyla başka düzleme yatırma gibi
??? Bizim istedigimiz Z degerlerinin 0(sıfırlanması ve vartex koordinatları(x,y ,0) değişmemesi
recep_xyz   17.01.2022 11:31 #16101
Arkadaşlar bu lisp X ve Y koordinatlarını koruyup Z degerini ya Z=0 veya Başlangıç ilk Z değerine sabitlemesi gerekmez mi Burada yatıgınız işlemlerde x,y koordinatlarda değişimler var bu olmamalı . Bİlen arkadaşlar bir incelesin işlem durumunda yanlışlık var.
SerdarBas   28.04.2016 08:47 #15659
HAY BEN SİZİN YAPACAĞINIZ LİSP' E ARKADAŞ KUSURA BAKMAYIN AMA LISPI UYGULADIKTAN SONRA EKRANA HER TIKLADIĞIMDA NOKTALAR OLUSUYOR REGEN YAPINCCA GIDIYOR SACMA SAPAN BİR ŞEY AYNI VIRUS GIBI
sibel_colak   05.01.2009 16:57 #10080
Ben bu kodu kendimce geliştirdim..
Kodda tek seçim yapılıyordu düzenlemiş olduğum kodda birden fazla 3d polyline seçilip polyline yapılıyor.
Paylaşmak istedim...
(defun c:p3p ()
(princ "n[Change 3D Polyline to Polyline.]")
(setq index 0)
(setq e(ssget))
(setq sayac (sslength e))
( repeat sayac
(setq en (ssname e index)
(command "pline")
);endwhile
(command "")
(command "ucs" "w")
(setq index(+ index 1))
);end C:P3P
Copyright © 2004-2026 | Tüm Hakları Saklıdır | 3702 | Site haritası | İstatistikler | Hakkımızda | Kadromuz | Gizlilik | Reklam | İletişim
SQL: 0.086 saniye - Sorgu: 37 - Ortalama: 0.00233 saniye | Insurance Quote Guide
